Using the CO2 sensor plugin
I saw there is a CO2 reading plugin that uses the scd30/4x sensor, but I didn’t understand how the sensor is used with the pioreactor, is there any examples or documentation on the hardware part?
Hi @almironeto the sensor is used externally, like in an incubator. There not currently an available design to have the sensor read the vial’s headspace.
If you’re looking for in-vial CO2 measurements you can use my lid design here
https://notes.livingphysics.org/build_posts/gen3_reactor_build/
Along with Atlas CO2 sensors, this design has been updated to include some gas injection and media exchange IO ports as well if you need them. The Atlas Sensors are i2c so should play fairly well with the Pioreactor software
If you need the step files or the version with the IO ports let me know!
The current design of the lid is only for the atlas sensor? How does it work?
My range is at 10% CO2, the sensair would be more fitting.
I have one now for the sensair 10% (K33 ICB 10% CO2 Sensor for Biological Science Applications – CO2 Meter). You simply have to unscrew the porting cover and screw this instead into the sensor housing. This sensor can also be read over i2c. In the image the sensair sensor is on the left and an Atlas O2 sensor is on the right.
This is the single K33 gas sensor vial lid , msg me if you’d like the step file! I will post a note about all this stuff at some point with the relevant files but happy to send you stuff in the meantime.
