Just getting back to using my pioreactor after several months. Because the pioreactor software was signfiicantly out of date, I’ve downloaded the new build. I previously had added our college’s device wifi network SSID to the wpa_supplicant.conf file, which allowed connection to registered MAC addresses instead of user/pw. In the latest version of the pioreactor software, it doesn’t look like I can add the SSID to that file anymore. The device boots just fine, but the only way I can connect to it is via setting up the local access point. Is there a way to add a network SSID after the device is set up?
Good question @drsingleton - there is! The latest OS uses a tool called NetworkManager (letting you know so you have some google-able terms). From the Pioreactor’s command line, you can add networks like:
nmcli device wifi connect <AP name> password <password>
nmcli has a few more options that might be need for your college’s wifi.
Note that when you run this, you’ll be kicked off the local-access-point (since it switches to try to connect to the colleges wifi). However, rebooting the Pioreactor will default to it’s local-access-point until you remove the local_access_point file from /boot/firmware (with the command sudo rm /boot/firmware/local_access_point).
Thanks Cam! I assumed that this had moved somewhere else. When I set up this new pioreactor, I did it at home where I can see what’s connected to the router and used the raspberry pi image writer to add my network. I used grep to find my SSID name and it wasn’t in the wpa_supplicant file like it had been in the earlier build. This helps a lot.
Does the pioled plugin still provide the IP address if it gets onto the network? Our college network also prevents logging in via the host alias (pio1.local), I have to connect via the IP address. I can get the IP address by finding my device on the college’s device registration webform, but they are dynamic addresses and having it displayed when it boots up is a time saver for me.
Yup, it should. Let me know if not, and I’ll run some tests locally and fix.
