Hello! I am trying to troubleshoot an error reoccurs when I run the Chemostat automation. Here is a log the error.
2022-12-29T19:54:10+0000 [dosing_automation] [app] INFO ErrorOccurred: '>' not supported between instances of 'str' and 'float'
2022-12-29T19:55:10+0000 [dosing_automation] [app] DEBUG '>' not supported between instances of 'str' and 'float'
File "/usr/local/lib/python3.9/dist-packages/pioreactor/automations/dosing/base.py", line 255, in run
event = self.execute()
File "/usr/local/lib/python3.9/dist-packages/pioreactor/automations/dosing/chemostat.py", line 33, in execute
volume_actually_cycled = self.execute_io_action(media_ml=self.volume, waste_ml=self.volume)
File "/usr/local/lib/python3.9/dist-packages/pioreactor/automations/dosing/base.py", line 302, in execute_io_action
elif media_ml > max_:
TypeError: '>' not supported between instances of 'str' and 'float'
I am new to both Raspberry Pi and Python, so sorry if I am missing something obvious. I would appreciate any advice on how to fix the issue or how I could try troubleshooting this type of issue myself.
Troubleshooting
I believe the problem is that when Python runs “elif media_ml > max_” in base.py, line 302, there is an error because either “media_ml” or “max_” is a string and the other is a float. Since “max_” is defined as “max_ = 0.625” in base.py, line 292, I believe “max_” is a float and “media_ml” must therefor be the string.
Since the error occurs when I run the Pioreactor through the web UI, I can think of several different causes for the error: (1) the web ui input type is stored as a string; (2) when a chemostat class is initialized, the input defaults to string and not float; or, (3) a chemostat class is initialized with the input as a float, but the float is converted into a string somewhere along the way.
1. web ui input type stored as string
I looked in chemostat.yaml to try and find more information about the web ui input but don’t see anything that helps.
2. the chemostat class is initialized with the input as a string.
Using the default values, I believe this would be: Chemostat( “chemostat”, duration = 20, volume = 0.5). Then, in chemostat.py:
class Chemostat(DosingAutomationJob):
Line 30 self.volume = volume # volume should be 0.5, but I don't know whether it is a float or string
Line 33 volume_actually_cycled = self.execute_io_action(media_ml=self.volume, waste_ml=self.volume)
I am not sure how to go about troubleshooting/debugging this area. I believe it is possible in Python to pause when this code is run and reaches Line 32. How could I do this (or what terms should I Google), and what Python commands could I use to get information on variables like “volume,” “self.volume,” or “media_ml” after entering “media_ml = self.volume”
- The float might be converted to a string when self.execute_io_action(media_ml = self.volume, waste_ml=self.volume)
I have looked through automations/dosing/base.py, but nothing jumped out at me as causing a float → string conversion.
Anyways, sorry for the wall of text. I am fairly new to both programming and Raspberry Pi, so I am not really sure how to continue troubleshooting this issue. Thanks!
