I have added two custom automation plugins. I followed the instructions in THIS post:
I added the .py files here:
pioreactor@leader.local:/home/pioreactor/.pioreactor/plugins
The yaml files are hosted here:
pioreactor@leader.local:/var/www/pioreactorui/contrib/automations/dosing/
I have no problem running them in the leader through the ui (Pioreactor → Manage → Dosing automation → Morbidostat LT). However, although they are available in the dosing automation options of the two workers (worker1 and worker2) of the cluster, when I click on “Start” a message appears (“Starting dosing automation”) but it doesn’t start. The same thing happens when I run another dosing automation from the ones available by default, such as “Chemostat”.
Is it necessary to copy the .py and .yaml files in each worker or, on the contrary, is there another way to do it?
I have tried to copy the files from my laptop to worker1 and I get the following message:
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ED25519 key sent by the remote host is
SHA256:gyi8UVwfxekl1+qfPJwqsDsEjrWY25Elga1IcMyzVz4.
Please contact your system administrator.
Add correct host key in /home/laptop/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /home/laptop/.ssh/known_hosts:10
remove with:
ssh-keygen -f "/home/laptop/.ssh/known_hosts" -R "worker1.local"
Host key for worker1.local has changed and you have requested strict checking.
Host key verification failed.
Well, I managed to copy the .py files to workers from the leader instead from my laptop. Anyway, this doesn’t fix fix the problem. When I check the plugin list in each pioreactor, I get the follow output:
pioreactor@leader:~ $ pio plugins list
/home/pioreactor/.pioreactor/plugins/__init__.py encountered plugin load error: attempted relative import with no known parent package
base==Unknown
chemostat==Unknown
fed_batch==Unknown
morbidostat_classic==Unknown
morbidostat_lt==Unknown
pid_morbidostat==Unknown
silent==Unknown
turbidostat==Unknown
pioreactor@leader:~ $ ssh pioreactor@worker1.local
Last login: Wed Jul 17 15:32:21 2024 from 192.168.1.220
pioreactor@worker1:~ $ pio plugins list
/home/pioreactor/.pioreactor/plugins/base.py encountered plugin load error: No module named 'pioreactor.background_jobs.dosing_control'
chemostat==Unknown
fed_batch==Unknown
silent==Unknown
pioreactor@worker1:~ $ ssh pioreactor@worker2.local
Last login: Wed Jul 17 15:34:41 2024 from 192.168.1.251
pioreactor@worker2:~ $ pio plugins list
chemostat==Unknown
fed_batch==Unknown
silent==Unknown
You need to copy the .py files over to the workers, yes. Not the .yaml. There’s an easy utility to copy files from the leader to all the workers in one command:
will send the leader’s file /home/pioreactor/.pioreactor/plugins/my_plugin.py to all the workers.
On the the next problem,
/home/pioreactor/.pioreactor/plugins/base.py encountered plugin load error: No module named ‘pioreactor.background_jobs.dosing_control’
We changed the API for dosing automations a few months back (in the 2024.7.18 release), and, looking back, I think we did a poor job of helping users migrate their existing automation plugins.
Can you share your base.py file here (or at info@pioreactor.com)? I can help migrate it.
(btw this error is technically harmless, and isn’t the source of the problem below)
So the current problem is that when you click Start from the UI to run the morbidostat_lt, it only runs on the leader, and not the workers? If so, can you try running it again, and show me the output of pio logs on the worker?
# -*- coding: utf-8 -*-
import time
from contextlib import suppress
from datetime import datetime
from functools import partial
from threading import Thread
from typing import Any
from typing import cast
from typing import Optional
from msgspec.json import decode
from msgspec.json import encode
from pioreactor import exc
from pioreactor import structs
from pioreactor import types as pt
from pioreactor.actions.pump import add_alt_media
from pioreactor.actions.pump import add_media
from pioreactor.actions.pump import remove_waste
from pioreactor.automations.base import AutomationJob
from pioreactor.background_jobs.dosing_control import DosingController
from pioreactor.config import config
from pioreactor.pubsub import QOS
from pioreactor.utils import is_pio_job_running
from pioreactor.utils import SummableDict
from pioreactor.utils.timing import current_utc_datetime
from pioreactor.utils.timing import RepeatedTimer
In addition, I realized that Temperature automations also just work in leader.
EDIT: This is the log from worker1 after rebooting and starting dosing automation (Chemostat):
2024-09-24T16:12:54+0200 [monitor] NOTICE worker1 is online and ready.
2024-09-24T16:12:54+0200 [monitor] INFO Ready.
2024-09-24T16:12:54+0200 [monitor] DEBUG monitor is blocking until disconnected.
2024-09-24T16:13:05+0200 [monitor] DEBUG Running `JOB_SOURCE=user EXPERIMENT=PRUEBA2 nohup pio run dosing_control --automation-name chemostat --skip-first-run 0 --duration 20 --volume 0.5 >/dev/null 2>&1 &` from monitor job.
display_name: Morbidostat LT
automation_name: morbidostat_lt
description: >
Modification of morbidostat classic control including a lower threshold.
fields:
- key: target_normalized_od
default: 0.2
unit: AU
label: Target nOD
type: numeric
- key: trigger_od_value
default: 0.1
unit: AU
label: Upper nOD threshold
type: numeric
- key: volume
default: 1.0
unit: mL
label: Volume
type: numeric
- key: duration
default: 0.25
unit: min
label: Time between check
disabled: True
type: numeric
If helpfull: morbidostat_lt.py
class MorbidostatLT(DosingAutomationJobContrib):
"""Adding a lower threshold to morbidostat classic control """
automation_name = "morbidostat_lt"
published_settings = {
"volume": {"datatype": "float", "settable": True, "unit": "mL"},
"target_normalized_od": {"datatype": "float", "settable": True, "unit": "AU"},
"trigger_od_value": {"datatype": "float", "settable": True, "unit": "AU"}, # New parameter
def __init__(self, target_normalized_od: float | str, volume: float | str, trigger_od_value: float | str, **kwargs):
super(MorbidostatLT, self).__init__(**kwargs)
with local_persistant_storage("current_pump_calibration") as cache:
if "media" not in cache:
raise CalibrationError("Media pump calibration must be performed first.")
elif "waste" not in cache:
raise CalibrationError("Waste pump calibration must be performed first.")
elif "alt_media" not in cache:
raise CalibrationError("Alt media pump calibration must be performed first.")
self.target_normalized_od = float(target_normalized_od)
self.volume = float(volume)
self.trigger_od_value = float(trigger_od_value) # Store the trigger OD value
self.trigger_reached = False # Boolean to check if the OD has passed the trigger value
def execute(self) -> events.AutomationEvent:
# Check if we have a previous OD reading
if self.previous_normalized_od is None:
return events.NoEvent("Skip first event to wait for OD readings.")
# Check if we have surpassed the trigger OD value
if not self.trigger_reached:
if self.latest_normalized_od >= self.trigger_od_value:
self.trigger_reached = True # Mark that the trigger has been reached
else:
return events.NoEvent(f"Waiting for OD to reach the trigger value {self.trigger_od_value:.2f} AU.")
# Proceed with normal operation only if the trigger has been reached
if self.trigger_reached:
if (
self.latest_normalized_od >= self.target_normalized_od
and self.latest_normalized_od >= self.previous_normalized_od
# If we are above the threshold, and growth rate is greater than dilution rate
self.execute_io_action(alt_media_ml=self.volume, waste_ml=self.volume)
return events.AddAltMediaEvent(
f"latest OD, {self.latest_normalized_od:.2f} >= Target OD, {self.target_normalized_od:.2f} and Latest OD, {self.latest_normalized_od:.2f} >= Previous OD, {self.previous_normalized_od:.2f}"
else:
self.execute_io_action(media_ml=self.volume, waste_ml=self.volume)
return events.DilutionEvent(
f"latest OD, {self.latest_normalized_od:.2f} < Target OD, {self.target_normalized_od:.2f} or Latest OD, {self.latest_normalized_od:.2f} < Previous OD, {self.previous_normalized_od:.2f}"
Try to update your cluster to the next version, 24.7.18, at least. Here are our docs on that process. The workers will “update” to 24.7.18, too, but this is harmless and won’t change them.
