I had a bit of difficulty getting an automation to appear in the UI, but I finally managed it. I did have a couple errors pop along the way though. I had several issues/areas of difficulty that I wanted to provide feedback on.
I based my dosing automation off the chemostat automation and I was referring to the adding plugins to the UI webpage.
- Unclear where to place Python file.
I ended up getting the alt_media_chemostat.py to appear in the pioreactor1.local/plugins page by placing the file in ~/.pioreactor/plugins/ directory, but it wasnât clear to me at first where to put it. On the linked âadding plugins to uiâ page, it shows where to place the .yaml files but doesnât mention the proper location to put the .py files.
- Where to place the .yaml files
The âadding plugins to uiâ suggests that /var/www/pioreactorui/contrib/jobs/ is for âdefaultâ jobs and /user/pioreactor/.pioreactor/plugins/ui/jobs is the directory for custom plugins. I had a bit of confusion arising from several sources. First, I think the path should say /*home*/pioreactor/... and not /user/pioreactor/.... I tried looking around /usr/ but wasnât finding anything pioreactor related (that I remember). Second, I didnât (at first) realize there was a distinction between adding a background job/custom python script/custom automation. I think something that might be useful is having a section at the top of the page that shows the various directory paths in one location and says what types of .yamls go where.
Lastly, I havenât been able to get my alt_chemostat.py automation to show up in the dosing automations when I placed them in the recommended directory (/home/pioreactor/.pioreactor/plugins/ui/automations/dosing/). I tried several times/locations and refreshed the web page, but was not able to get it to appear. I was only able to get my new automation to appear when I placed it in /var/www/pioreactorui/contrib/automations/.
- YAML errors with unknown fields.
I encountered several errors in the recent event log saying âObject contains unknown field [e.g., âdescriptionâ]â. The reason for this error was that I structured my .yaml file after the .yaml example in âAdding a custom background job to the list of activitiesâ. This example contains several fields (e.g., display, description, published_settings, type, etcâŚ) that will give errors if youâre adding a custom automation. I didnât see anything to indicate that the allowable objects for a custom automation are different from the allowable objects for a background job.
- General difficulty navigating file system.
I would find it helpful to have a reference page somewhere that lists most/all of the different directories with pioreactor files. This might be partially due to my inexperience with linux/Raspberry Pi, but I tend to have some difficulty remembering where things are or navigating through the Piâs directories.
Automation File
File Location: /home/pioreactor/.pioreactor/plugins/alt_media_chemostat.py
# -*- coding: utf-8 -*-
__plugin_summary__ = "An extension of the chemostat automation to allow a second media source."
__plugin_version__ = "0.0.1"
__plugin_name__ = "Alt Chemostat Automation"
__plugin_author__ = "realPeteDavidson"
__plugin_homepage__ = "https://docs.pioreactor.com"
class AltChemostat(DosingAutomationJobContrib):
Alternate Chemostat mode - try to keep [media] and [alt_media] constant.
automation_name = "alt_chemostat"
published_settings = {
"media_volume": {"datatype": "float", "settable": True, "unit": "mL"},
"alt_media_volume": {"datatype": "float", "settable": True, "unit": "mL"},
def __init__(self, media_volume: float | str, alt_media_volume: float | str, **kwargs) -> None:
super().__init__(**kwargs)
with local_persistant_storage("current_pump_calibration") as cache:
if "media" not in cache:
raise CalibrationError("Media pump calibration must be performed first.")
elif "waste" not in cache:
raise CalibrationError("Waste pump calibration must be performed first.")
elif "alt_media" not in cache:
raise CalibrationError("Alt_Media pump calibration must be performed first.")
self.media = float(media_volume)
self.alt_media = float(alt_media_volume)
self.volume = self.media + self.alt_media
volume_actually_cycled = self.execute_io_action(media_ml = self.media, alt_media_ml = self.alt_media, waste_ml = self.volume)
return events.DilutionEvent(
f"exchanged {volume_actually_cycled['waste_ml']}mL",
data={"volume_actually_cycled": volume_actually_cycled["waste_ml"]},
Working YAML
File Location: /var/www/pioreactorui/contrib/automations/dosing/alt_chemostat.yaml
display_name: Alternate Chemostat
automation_name: alt_chemostat
description: Testing for now.
fields:
- key: media_volume
unit: mL
label: Added media volume
default: 0.5
- key: alt_media_volume
unit: mL
label: Added alt_media volume
default: 0.1
- key: duration
unit: min
label: Duration
default: 20
Not-Working YAML
File Location: /home/pioreactor/.pioreactor/plugins/ui/automations/dosing/alt_chemostat.yaml
display: True
source: Alt Chemostat Automation
published_settings:
- key: media_volume
unit: mL
description: Media to be added each duration.
type: numeric
default: 0.5
display: true
unit: mL
description: Alt media to be added each duration.
type: numeric
default: 0.1
display: true
- key: duration
unit: min
label: Duration
description: Time between media and alt_media additions.
type: numeric
default: 20
display: true
