We are having problem with accessing the user interface (UI) through our local access point.
The local access point can still be accessed through the command line, however, the UI is remains to be down and cannot be accessed.
Upon troubleshooting, running pio update ui on the leader results with the error log:
Job for huey.service failed because the control process exited with error code.
See “systemctl status huey.service” and “journalctl -xeu huey.service” for details.
2024-07-25T11:46:36+0200 DEBUG [update_ui] wget https://github.com/pioreactor/pioreactorui/archive/refs/tags/24.7.19.tar.gz -O /tmp/pioreactorui.tar.gz
2024-07-25T11:46:39+0200 DEBUG [update_ui] bash /usr/local/bin/update_ui.sh /tmp/pioreactorui.tar.gz
2024-07-25T11:46:41+0200 ERROR [update_ui] + set -e
+ export LC_ALL=C
+ LC_ALL=C
+ SRC_TAR=/tmp/pioreactorui.tar.gz
++ mktemp -d -t pioreactorui_XXXX
+ TEMP_DIR=/tmp/pioreactorui_8lQz
+ UI_FOLDER=/var/www/pioreactorui
+ trap finish EXIT
+ tar -xzf /tmp/pioreactorui.tar.gz -C /tmp/pioreactorui_8lQz
++ find /tmp/pioreactorui_8lQz -mindepth 1 -maxdepth 1 -type d
+ WORK_DIR=/tmp/pioreactorui_8lQz/pioreactorui-24.7.19
+ echo /tmp/pioreactorui_8lQz/pioreactorui-24.7.19
+ [[ -z /tmp/pioreactorui_8lQz/pioreactorui-24.7.19 ]]
+ rsync -ap --ignore-existing /var/www/pioreactorui/contrib/ /tmp/pioreactorui_8lQz/pioreactorui-24.7.19/contrib/
+ cp -p /var/www/pioreactorui/.env /tmp/pioreactorui_8lQz/pioreactorui-24.7.19
+ rm -rf /var/www/pioreactorui
+ mkdir /var/www/pioreactorui
+ cp -rp /tmp/pioreactorui_8lQz/pioreactorui-24.7.19/. /var/www/pioreactorui
+ chgrp -R www-data /var/www/pioreactorui
+ ENV=/var/www/pioreactorui/.env
+ '[' -f /var/www/pioreactorui/.env ']'
+ echo '/var/www/pioreactorui/.env exists.'
+ finish
+ rm -rf /tmp/pioreactorui_8lQz
+ sudo systemctl restart lighttpd.service
+ sudo systemctl restart huey.service
See "systemctl status huey.service" and "journalctl -xeu huey.service" for details.
sys.exit(pio())
File "/usr/local/lib/python3.11/dist-packages/pioreactor/cli/pio.py", line 686, in update_ui
raise exc.BashScriptError(p.stderr)
pioreactor.exc.BashScriptError: + set -e
+ export LC_ALL=C
+ LC_ALL=C
+ trap finish EXIT
+ finish
We tried:
- Rebooting the leader
- Updating the leader app with lower software version - i.e., 24.6.10
- Reinstalling huey.whl through wheels_24.7.18.zip
However, none of the attempts solved the problem.
Did anyone encountered a similar issue or have an idea of a potential solution for this problem?
