Note: There was a bug in 23.2.6, so a hotfix patch, 23.2.8, was released.
23.2.8
Bug fix
- Fix error in growth rate calculating job that prevented it from starting.
23.2.6
New features
- Watchdog job now listens for new workers that join the network and are not part of the cluster. A NOTICE message is logged and sent to the UI.
- Initial API support for adding more pumps to the Pioreactor. See docs here.
- Time series charts are now able to be added the the UI via
contrib
folders. Put a yaml file under~/.pioreactor/plugins/ui/contrib/charts
. See examples here. - New roll-up table available to be exported from the UI: Pioreactor unit activity data roll-up. This is a rolled-up of Pioreactor unit activity data rolled up to every minute, so it should be about one order of magnitude less data versus the original table.
API changes
- Pioreactor UI has a more RESTful API, so some internal urls have changed. See full new API here. UI version >= 23.2.0 required.
SummableList
is replaced withSummableDict
execute_io_action
returns a dictionary now (instead of a list).- Config: Removed
daily_growth_rate
from[ui.overview.settings]
- Config: Added
implied_daily_growth_rate
under[ui.overview.charts]
- Dropped
pio run-always
. Jobs just usepio run
now.
Problems? Let me know here or at cam@pioreactor.com
