Got it - thanks for clearing up!
Aha - 1L is pretty awesome, but probably bigger than I need for my home experiments, at least right now =). However, I figured 100mL might be perfect, and so was really excited when the release notes mentioned a custom 100mL size
I did another forum search - and I found this earlier thread, which references these two efforts:
Both of these seem to use a larger vessel (500mL or 1L), which then pumps liquid continually through the smaller standard size Pioreactor vessel. It looks really awesome - but might be overkill for my setup at this stage - I suspect I’m going to have enough trouble trying to keep everything sterile/aseptic with a single vessel (although being able to integrate in the Atlas Scientific pH probes is pretty cool).
Do you happen to know if there’s any 100mL single vessel solutions people might have mentioned, in that video call you were on, or that you’ve heard of? Or anything in between 40mL and 500mL, that’s simpler for somebody starting out to get going? (I’m not sure what the size/volume limits are, in terms of the OD readings on the PioReGot it - thanks for clearing up!
Do you happen to know if there’s any 100mL single vessel solutions people might have mentioned, in that video call you were on, or that you’ve heard of? Or anything in between 40mL and 500mL, that’s simpler for somebody starting out to get going? (I’m not sure what the size/volume limits are, in terms of the OD readings on the PioReactor are - but would be curious if somebody has done the math).
